[solved] Can't sustain RPMs above 3000?
Hey CX500 fam,
My 82 CX500C seems to not be getting enough gas to sustain RPMs above about 3000. I had taken the carbs off to fix an air leak issue (the metal part between the carb boot and the cylinder head was cracked, I got the bike that way), and now I have re-assembled them (they were very clean on the inside), put them back on, and have it running fine as long as I'm below 3000 RPMs.
Basically, when I give it gas I will go to whatever RPM I want for 3-4 seconds and run as normal, but then it will start to stutter and rev down, then will almost stall it will usually backfire a time or two or three until I let up on the throttle, give it some time, and then I can rev it back up again. My supervisor thought that it was the floats needed adjusting, but I read somewhere they aren't really adjustable because they're plastic... Another friend thought maybe a jet was blocked, but I don't think that's the case either because the carbs were very clean even before I took them apart.
I ran it with the choke on, that didn't make a difference, then I took the air filter out to let it suck air more easily and that made no difference either, so I don't think it's a mixture issue...
edit: I removed the fuel filter and ran it like that, made no difference there either...
My best guess, is that the accelerator pump diaphragm/rod piece is either bad or misaligned, but I'd like to hear your thoughts if there is anything else I should try before taking the carbs all the way back off.
Does that sound right? Has anyone else had trouble like this?
edit: also adding to the original post but you'll see it further down as well... turns out I'm a total noob (this is my first carbs I've ever taken off of a bike)... I had simply not lined up the vacuum cylinders with the little groove on the side (I did not realize it was necessary to do so, and my manual didn't tell me otherwise)...now it runs just like it did before I made the poor decision of removing the carbs in the first place (it wasn't necessary, my only issue was the crack in the piece that goes between the cylinder head and carb boot).
thanks - you guys/this forum are great,
gabe
Hey CX500 fam,
gabe
