I will give that a shot. Thanks for the suggestion.
The main problem with the stock o-ring in the turbos is it flattens out really quickly, especially if you get a new old stock o-ring- it
could be 10-15 years old. Oversized o-rings still flatten out, but as they are crushed, they completely fill the gap.
I have used this method on other oil sealing o-rings as well.
You may also want to look for burrs, cracks, or chips in the area that could be scoring the o-ring, or preventing a good seal.
As a last resort with a stock sized o-ring, you could apply a thin layer of Hondabond sealer around the o-ring.
If you choose to do this, make absolutely sure that the surfaces are absolutely free of oil, and let the Hondabond dry for 48 hours before firing up the engine. If the Hondabond is even a little bit tacky before you fire the bike up, this method
will fail.
