Is camchain adjustment a do it yourself deal? How often should it be done?
When it say loosen only go one or two turns max. Otherwise the bolt may back out of the hole far enough for the spring to pull it off center and then you have to remove the rear cover to put it back in.Thank you. I have a spare engine I'll work on it 1st.
I noticed that when I adjusted my Cam-chain (gl 500, but prolly the same for all save the manual type), that I could back off the bolt a coupla turns and then it got a little harder to to back off, so I didn't "press" the issue.....Lol
Well if you can or cant I'm not going to try it. But if anyone else wants to then fill us in.
I just did this. I marked the bolt so I would know when I got to two full turns. Just when I got it there, it wouldn't turn any more.
now that makes me wish i still had my parts bike so i could report the findings but alas it is gone........and shouldnt you adjust the cam chain when the engine is stone cold??or is that just for the valves?
