Okay, brand new here. Glad I finally found a forum related to my '82 GL500I. Love this bike. I've had it for a little over a year and I have just recently started having issues.
I was forced to let the bike sit for about 3 months and the guy I left the bike with only started it a couple of times while I was away. Ran great before that, but after that, started noticing less and less power. Thought I had carb issues until I finally did a compression test and discovered I had a cracked (yes, cracked) valve. Fixed that and it ran great for about 3 days. Then I start hearing "tap, tap, tap". Checked the tappet clearances multiple times and finally found this website and some really good advice and pix. I'm wondering if maybe I had the valves adjusted improperly the first time I did it (months ago), which caused the cracked valve and also affected the chain and tensioner?
After seeing other postings here, I bought a small dental mirror and checked inside the inspection cover and saw the tensioner slot just like the pic with the caption "if it looks like this, you're dead." Great. I'm only hoping I can come up with the $200 or so for all the parts I'll need. This is my first time in and probably the first time it's ever been opened up at 40,000 mi. I have pretty good mechanics skills but my main worries are getting the exhaust off and the fairing mount bracket. I put an aftermarket electric fan on it after I went through 3 oem fans in less than a year. While I was doing that, I never really got that bracket off.
1.Does the front fender have to come off to get the fairing mount bracket off?
2. Can I pull the exhaust by just pulling the headers out of the heads and removing the mounting bolts elsewhere, or does the whole thing need to come apart? It's pretty well rusted together at the hbox.
3. What is the best way to remove the water pump impeller? I've had the housing off and that cap nut off and it didn't exactly slide right off. I don't want to pry on it or grab hold of it with channel locks...
Thanks in advance, and I'll try to keep this thread updated on my progress
