82 GL 500I
The bike has been running great with no apparent issues since getting it back together in late April. I've put close to 3000 miles on in it. Recently with the temps rising, i see more coolant leak topics arising and yes I now have one. Seems to be coming from the fan area. I've checked the hoses and they are dry. Could I have a fan bolt issue? Also, noticed a nut backed out from one of the motor mounts located under the handle bars. The Bolt is still there, so maybe the excess vibration and the add the heat and finally the leak appeared. I'm speculating here. My fear is with the motor mount loose, maybe I damaged the cam?? Any takers here?
Second. My cam chain bolt seem to have oil coming from it. Is it the o-ring?? If so can I back it all the way out to replace??
deuce
deuce
