A couple of issues I could use a bit of help with:
1. Once the old cam chain is off how do you turn the camshaft to bring it back to TDC before installing the new one? I don't have a 27mm socket to turn the nut on the end of the shaft. Should I just reinstall the fan and use it to turn the camshaft?
2. For Shep's Mech. Seal replacement method how do you remove the old seal and spring from the metal cup? Should I just apply heat to the back of the cup or pry it off with a screwdriver?
