OK... More info added. I will continue to work on my profile here, if I can keep myself out of the garage. I think I scored today. I bought a 1979 CX500 custom for $50. It was minus the gas tank, all other parts are there, though some will need replaced. It did not have a key, so I took the ignition out tonight and sent Kilroy a message. This bike was purchased brand new in 1980. The owner drove it for about 10 years then parked it. It has sat for over 20 years, sometimes inside and sometimes outside. Unfortunately, there is a good bit of rust, but most of it is surface rust. I took the exhaust off tonight as it was rusted terribly. I drained the oil, which looked good. The engine turns, so that is a relief. The transmission shifts gears, and the rear brake works, though it is a bit squishy. The front brake lever will not move and the master cylinder reservoir is cracked. I will have to replace that. The throttle also seems stuck. Once I get a key, I plan on testing the ignition/starter. If that works, I will make sure I am getting spark to the plugs. If that all goes ok, I will see if I can get the engine to fire, though I am pretty confident I will have to rebuild the carbs since it sat so long. I hope to get it mechanically sound and ride it a little bit this summer. In the fall, I will tear it down and start sanding and painting. Next spring will be fun! It has been a while since I have had a project like this, and it was just what I needed. I spent two hours in the garage and feel completely relaxed. Reading this forum inspired me to go ahead and start this project, so thanks!
