I've got big plans for this '81. I bought it for $200. The engine has 70k miles, turns over but is non-running. The carbs are gunky, the forks leak, the compression is down in the 120s, some of the electrical system appears to be fried, it's missing a LOT of parts, and it's just ugly in general - seems like a good candidate for a total re-imagining to me!
Here's what I'm starting with. The previous owner had stripped off all the fairings & panels and cut up a custom tailpiece from a Sportster fuel tank, and fabbed a shock mount for a Ducati 999 rear shock:
I plan to go a bit further with this than just a seat pan and clip-ons. I'm stripping the bike down to nuts & bolts, and here's some of the work I have in store for the next few months:
- Mikuni carbs, pods, true dual pipes (lose the H box), mufflers
- Grind the cam to squeeze out a couple more HP
- Structural strengthening of PO's custom shock bracing with steel bracing
- Remove the engine, inspect & deep-clean, adjust valves, possibly replace piston rings, water pump, stator, & cam chain if needed upon testing
- Replace all rubber parts due to age and the bike sitting for years
- Powdercoat the frame, swingarm, wheels
- Rebuild forks & stiffen with spacers
- Bigger front brake caliper or more modern disc if needed after testing
- Modern lights, gauges
- CX500 deluxe fuel tank
I'll be using this thread to field the issues I run into along the way. This is a great forum so far!
Cheers,
--Carter
Cheers,
--Carter
