About any decent stripper seems to work on the Honda clear, however the nasty ones that contain methylene chloride listed on the back of the can as a base work a heck of a lot faster with less chances you'll have to give it a second coat.
Methylene Chloride is nasty stuff, you need skin protection and good ventilation (ie: outside) as base protection and I've always found that to be sufficient if I'm just doing a small part or two - you don't want to try and work too big of an area anyway. You just want to lay a thick coat on, there is no reason to try and work it in or anything else. It usually takes 10 - 15 minutes tops until it's all bubbled up and ready to be removed, watch carefully and test with a scrap piece of wood as you don't want it to dry back up or you've got an even harder mess to strip when you have to start over. Once it's softened everything up - but before it starts to dry up again - remove the stuff using a small nylon scrub brush and running water. (Warm and soapy is best)
If for some reason you didn't get it all the first time let the workpiece completely dry of all water before re-applying and getting the last of it.
