1 - 10 of 10 Posts
Started hearing loud clanking after loss of power yesterday, when I pulled the front engine cover I found metal shards fall out. Any ideas?
201560
201561
Those are pieces of what used to be a piston! Pull the valve covers off and I'm sure you'll have valve stems sitting higher than normal.
You probably dropped a valve or 2 and they jammed between the head and the piston. That had to have made quit a racket when it blew!
Discussion Starter #3
sadly i think it’s done for now. I did some searching online and I’m guessing I’ll have to completely open it up :/
Pull the spark plugs out and look at the ends of them. The bad side will have the end of the plug all chewed up and the gap jammed shut.
You might as well pull that head off if only out of curiosity to verify the cylinder walls are ruined, and post pics.
Worst case you now have a parts engine.
Just convert it to a single cylinder..
Reactions: Sidecar Bob
1 - 10 of 10 Posts
