1 - 6 of 6 Posts
Assuming you mean the cam chain adjuster bolt - engine out, rear cover off, inspect damage... Hopefully thread not stripped in block, but if the bolt is now loose and will not tighten, then it probably is stripped...
It’s broke off in the block did that while I was taking the back casing off
1 - 6 of 6 Posts
