The latest project bike had some really ugly brake fluid streaks on the lower right side of the fairing. Obviously a previous owner had an accident while filling the master cylinder.
After thoroughly cleaning the area and letting it dry, I tried heating the streaks with an electric heat gun. The results were very pleasing - the streaks went from being simply awful to barely noticeable.
The trick was to get it hot enough that the surface just barely started to melt. As the outermost surface began to flow the color turned black again.
Too much heat will cause the texture to be lost, so it is important to work slowly and gradually raise the temperature.
