hi all, i have just completely changed out the front and rear brake systems (calipper/master rebuilds and SS lines).
i did the rear first and all went good ,bled the brake to a firm firm peddle.
now i have done the fronts and i cant get any pressure at the lever, i have fluid without bubbles from both calipers but the pistons are not moving at all.
no leaks .
i made a sleeve to push the piston thro in the master cylinder ,so i dont think the sleal has turned over.
and i put a 3/4 block on the grip to stop overtravel as per the manual.
any help would be appreciated.
cheers mark.
no leaks .
cheers mark.
