Having recently landed a 1980 CX500C with 17,800 original miles, I am extremely thankful for this forum. I'm good with everything else I've tackled so far, but this just plain baffles me totally:
Plastic floats, non-adjustable, without compressing the needle spring, read .750" (19.0mm) one side and >yikes< .820" (20.85mm) on the other side. a far cry from 15.5mm (.610" for those that don't measure bi-lingually). High reading means the fuel level is pretty horrifically low, right(?). I'm surprised it ran at all (had a broken throttle cable when I bought it, but I could rev it with a screwdriver). The bowls would overflow some when parked with gas left on, maybe that's why it ran decently? Anyway, I cleaned up everything and ordered new float needles.
I've swapped floats and old needles in various combinations back and forth between carbs and the crazy readings follow the float wherever it ends up.
It also seems bizarre to me that the old floats would wander off in the >low< direction (rather than bending 'up' with the usual forces at play over 31 years).
I'm in need of some sanity here, am I doing anything wrong? How do I get around this? The hairdryer bendy trick? If I get used floats, the situation could be worse (if that's possible), and NOS floats are like 50USD each...
please jump in SOON
thanks
mike
please jump in SOON
thanks
mike
