1 - 13 of 13 Posts
didnt know the age of the battery that came with the 82.so when it started to go flat within a few days of charging,so i bought another.
its still happening.started this morning ok,drove 5 miles to work,2 hours later,no start.
iv daves trouble shooting paperwork in front of me so...
when it wouldnt start.....12.8 v across the terminals.
2 hour slow charge........12.47 v across the terminals.
but it started no problem.
battery voltage while cranking[kill to off]...9.8 volts.
now its started ill go and check the volts at 2000 rpm
nb.green earth under seat clean and good.
anyone hazzard a guess
Discussion Starter · #2 ·
at 2800rpm the meter started across the terminals at 12.9 volts quickly rising[over one minute] gradually to 14.2v and held fast
Check out the 3 yellow wire connection from the engine. Since the bike feeds off the battery first maybe it isn't replenishing itself right away. I would also check the headlight bulb to see if the correct one is in there. Someone could have slid in a 100watt.
thks don,the head light is fine,i replaced the bulb last winter.
if the stator was bad,would i get 14 plus volts at 3k rpm
Put a 12v bulb in circuit at the battery as if you were testing current e.g in series.With the ignition off the bulb should NOT glow.If it does you have a short bleeding current out of the battery.
Also yellow wire stator check,
http://globalcxglvtwins.hostingdelivered.com/viewtopic.php?f=8&t=30
HTH
thanks again shep,ill give that a try,thats what it feels like is happening.
for now i took the battery off of sunflower seed and used that.
sodslaw,the minute i get an issue,iv no internet at home or work
Probably dying a bit but not dead. Do you have a meter you can hook up on the bike and read as you go to see if it jumps around or sticks to one place?
Try cleaning the starter ... it shouldn't drop that much while trying to start the bike.
I would def try and monitor charging system voltage while riding as stated above. Where did you get your new battery from? I went through 2 batteries on my 76 gl 1000 project because they were from walmart, the ones you need to fill with the acid. My first one died because I didnt charge it long enough after filling. Its got to be a bad battery, bad charging system, or excessive draw. Just need to rule out each cause one at a time.
HTH
thanks don,shep,tdn and david.following dave f,s trouble shooting page i went through the checks,all checked out fine.on his page he issues a warning about new batteries.........
saturday night i ended up pinching the battery of sunflower and put it on.had 150 miles of riding yesterday,the bike started instant every time , and again this morning to come to work.
bottom line....one brand new faulty battery.
so as dave,f said....dont assume a new battery is a good battery
thanks again,im back on the road
So what kind of brand new non faulty battery did you get?
from the uk
MF CB14L-A2.
its funny don,prior to my post above,shep emailed me,saying .....if you bought an MF battery....they are shi$.....my mate went through[as above]
oh well,onwards and upwards.
the battery i have on now[from sunflower] does not crank the bike,its just instant ignition
from the uk
MF CB14L-A2.
The battery is a CB14LA2 190 CCA Dynavolt,
http://www.dynavolt.co.uk/fastmovers.aspx
1 - 13 of 13 Posts
