Last Thursday night a friend and I went out for a ride... My Cx has been running like a dream and then; shortly after my bike reached it's terminal operating temp, the Deuce started to cough and sputter a little bit on acceleration, clearing out eventually but running a bit rough. Visions of Bad Coils and fouled plugs filled my head. After a break to let things cool off, check the obvious, and to speculate as to why a bike running perfectly one day would suddenly act as if it had been possesed by Satan's mechanic, we headed out for another attempt. This time things really started getting bizzare as If my ignition was completely intermittant. No power on take off or sometimes with a sudden burst of acceleration in turns. I limped home barely able to keep it running on one or the other cylinder. Backfiring and sputtering all the way... rolling through stop signs, just to keep rolling as she wanted to kill...
My Bud said he thought I was lean, I smelled "rich" ( I knew my left side had some past issues in the fuel management dept (i.e. leaky boot) ... a quick inpection of the plugs revealed nothing obvious, they both looked perfect. At this point, I was seeing all of the forums past threads about pulling motors, replacing seals, blown cooling fans, bad temp guages, .. and wondering if I had not floated a valve on one of my past the red line excursions sending a con rod out through the top or maybe breaking a knibbler pin deep in the dark neither regions of the motor... I was "worried" to say the least.
To make a long story short (r) I have spent the last few days pouring over the shop manny, this forum, Sheps forum, Randakks and anywhere else I thought might help... I even almost posted aWTF "guess what's wrong" thread yesterday. I replaced my fusible link and the fuse on the relay/ switch ground. ( light green, black stripe on 82's). Re did my main ground, checked the starter and kill switch for continuity, god rid of the resistors in my plug wires and changed plugs that were almost new... Went through the airbox, checked for leaks... som other things I can't remember like the choke operation and petcock... I think I may have even replaced the air in the tires.
nothing seemed to change anything...the bike hardly wanted to start... I was crestfallen... Fuzzy Visions of helplessly emptying my wallet into a mechanical vortex danced in my head. I wanted to drink.
Yesterday after reading the "long distance cx" thread, all six pages. I was re-inspired by the self reliant "go get em" attitude shown by so many here. (thanks Y'all) I was not going to let this deuce be-devil me into submission. Then,,, I realized. The only change I had made between the bike running well and the appeance of it's evil turd brother the next day was that I had added about 3/4 of a tank of new fuel from one of my ethanol free containers, or so I thought... Just for a lark, I hooked the patient up the bench fuel IV bottle. And dang nabbit damm sho nuff I had put bad fuel into my tank. She ran like it was 8 days before all this. I dumped the tank of whatever, put in new E free 87.... and zooooooom.
I figure one of these days, it WILL be more serious... Maybe a flebostat, or johnson rod replacement. until then, I must go write on the blackboard 496 times...
Even if it is all simple stuff, Check the simple stuff first... especially the simple stuff I might screw up... and go label the fuel containers.
From Area 51, 52.... whatever it takes.
Vox!
