My 82 GL500I Silver Wing, 33K on the clock, is leaking antifreeze (and some oil?) apparently (best I can tell prior to removing the radiator) from around the fan shaft, enough to make a mess of the engine and speckle my boot during my most recent 50 mile ride and enough to mess the garage floor with both oil and some antifreeze. I was worried the fan had disintegrated and bit the radiator, but upon initial inspection, the fan appears solid.
From what I can tell, if I remove the radiator and the water pump, then perhaps the seal might be replaced.
Thanks in advance for your suggestions/enouragement/links to previous posts.
Nebraska
(Presently located in Louisville, KY)
Nebraska
