Needing some advice! My bike is down right now getting painted, and my wife's bike (which I've been riding) is bottoming out the front forks when I stop. I can't have both bikes down, so I don't want to tear into the forks right now. What do you suppose I do? I see a little oil coming from around the seals and coating the upper tubes. I don't know if there is any air in them, because I haven't checked. Do you put oil in by removing the top caps? Should I put any oil in since I don't know how much is in there? Should I put the recommended amount of air into the forks and see if it helps, or will it just leak out and maybe blow the worn seals? Any help would be appreciated. Thanks in advance.
