1 - 3 of 3 Posts
my bike has a small leak. it is under the intake it is a plate with a pipe runing into it . looks like leaking under plate . where can i get a gasket for it?
On the left side in front of the carbs?
If so that's the Mechanical seal. Not a normal gasket? If the bike hasn't been used in a long time it may just need a good run to clean up this problem otherwise you will need to change it.
1 - 3 of 3 Posts
