Hi, I wondered if someone could help me out with the wiring for the speedo I'm fitting.
I've got everything working apart from the oil light. The blue and red wire from the oil pressure switch is in the head light housing and I've attached an image of the speedo
199662
wiring.
Does anyone have an idea of how best to connect this up?
Many thanks
It should work. Try running the wire you have running to the sender directly to ground. The light should light. If it lights the sender is faulty. If not, the fault lies elsewhere.
Verify the power wire actually does have power.
Discussion Starter #5
Thanks cxphreak, it was the sender, replaced it and all good.
