So i came across some aftermarket carbs on ebay and i wanted to know if anyone has used them? I know that the stock ones on mine are 38 year old technology so it couldnt hurt! Anyone have anythoughts on this?
Even the production racers at Bonneville have to run the stock carbs and they run 113 mph (at altitude). Unless you are planning to add a camshaft, headwork, pistons, and a trick exhaust, I wouldn't waste the time or money. If the carbs are in bad shape, buy some of Larry's or have him do yours. Getting more "umph" out of the CX gets real expensive because of the lack of parts (ie no demand). Good luck.thank you for the advice i dont know to much about motorcycles but i work on cars for a living and i know on car or any engine for that matter it how everything works together as a whole. You can put on some kickin carbs but the intake or exhaust isnt very good with the setup and get less hp out of it. Im just looking for a way to get more umph from this 500cc motor and if i cant then i think i will be doing some sort of motor swap to a 650 or see what all is different about the motors.
The carbs are from a Polaris snowmobile. Not sure of the model. They foul the frame bracket but since I am using the GL rear case that is not an issue any more. Originally I just lightly modified the brackets. The original carbs are 38mm but they are not smoothbores and the difference is abot 2mm as a rule of thumb due to no restrictions in the ventury. The new set ($75) is from a Artic Cat and even though the carbs are similar there are differences such as the cable facing the rear of the bike. This will be overcome with a round directional cable pulley to provide 90-180 degrees of cable rotation. This conversion is not for novices as there is tons of work to make them fit. They need to be spaced properly and the air filters are a royal PITA to fit. Just got 2 air filters for $30. The exhaust has been modified again and placed on my steam punk project in full swing at this time. I made another for the cafe racer and used a Ducati 848 muffler to keep the bike quiet for my early morning Saturday departures. The steampunk is sporting a 600rr UPS front end and it will be a fine ride when finished. Tis project is for my friend who got the second CX that was in my garage as a parts bike. The porting and higher compression does help with the output but since I have never ridden a stock CX it is hard to judge. There was a difference between the stock motor with the new headers and the modified motor. It sounded much louder.Scudman, good for you I love the American ''can do'' spirit ha ha. If you don't mind what model Mikuni flat slides?
What are the from originally? OEM or aftermarket? Are they the TM or RS?
My first thought was that's too much carburetor for a 500cc motor?
Did you have any fitment problems to the carb holders and height? I have my two into one headers
that start out the same as your's then step up two more times .125" each step to the merge collector.
Bonneville Jim has a cam and then some porting work would make that engine come alive I'd guess?
Cheers, 50gary
thank you so much this is exactly what i wanted to hear and see! I love my cx500, its no ducati (my other bike) but its fun. thanks alot again everyone.
Rattle rattle rattle.
Loud clutches save livesRattle rattle rattle.
Who's Larry and how much are his carbs?Even the production racers at Bonneville have to run the stock carbs and they run 113 mph (at altitude). Unless you are planning to add a camshaft, headwork, pistons, and a trick exhaust, I wouldn't waste the time or money. If the carbs are in bad shape, buy some of Larry's or have him do yours. Getting more "umph" out of the CX gets real expensive because of the lack of parts
Ed
