So while cleaning the carbs I noticed my acccelerator pump barely moved up and down (less than a MM), and I noticed that it's default position was touching the metal stop connected to a spring/nut combo.
Questions:
1. What does this rod do?
2. Should I adjust the stop so it has 3 mm of play, or does it pull downwards up to 3 mm?
3. Does anyone want a throttle stop screw? I apparently bought two.
Questions:
