1 - 6 of 6 Posts
I am trying to get my GL650I up to original condition or close to original. I have seen a photo that shows this bike with a PVC valve screwed into the inspection port on the rear cover. The parts fische does not show the PVC valve, is my bike a California model or??? Where can I get a PVC valve for it??? Some of you GL650 owners may have an answer for this.
It's not really a PCV valve per se (it's hollow).
If you look at the modern microfiche schematics, the part is not even listed, not in the European or American specs for either the GL650 standard or GL650I.
I assume this part was thought to be necessary for proper crankcase ventilation. Should I try to find a suitable replacement for this item???
I don't think that it is necessary.
The GL650 is also ventilated near the back of the engine casing, just like the CX650.
I have never really been able to figure out why the GL is ventilated the way it is.
I find that this design tends to suck up more oil into the air filter because the crankcase ventilation port is directly below the air filter. Kind of stupid, really.
The crankcase is specifically vented to the airbox so the blowby fumes will be sucked into the engine and burned. Blowby fumes are nothing if not unburned hydrocarbons and water. The white chamber below the airbox is the vapor separator where the majority of the oil droplets will settle out from the vapor, if the engine should be so sick as to pump out that much oil. All part of the effort to minimize smog...
i have a 82 gl500i (usa)part # are
cyl head plug # 90547-415-305
timing inspection / breather plug #12361-415-610
o ring 91302-001-000
breather tube 95005-12460-20
out of haynes manual #442
any one have any drawings or pic's of what this looks like ?
& how the breather cap hooks into OEM breather tubes to air box ?
newbie here help please ?
1 - 6 of 6 Posts
