1 - 19 of 19 Posts
Look at the picture. That little bugger with the arrow pointing to it fell out of my carb while I was overhauling (ruining) it.
The prize? I am Landed Gentry here in England so I can bestow a title on you if you answer the question. Arise Lord ******* of Arknasas
It kind of looks like the little Oring that goes on the air cutoff valve.
I think someone threw it in your carbs just to screw with you. Do they both have one?
I have Larry's carb book out right now and I don't see anything like that.
Did all of those O rings come out of one carb? I don't remember that many in there. The 80 model, I don't think has a accelerator pump(?). The idle mixture O ring would seem to be smaller than any pictured. That would just leave the transfer tube O ring, and the ACV O ring as the complete lot. Is it hard rubber? The bumper stop in the vacuum cylinder uses a hard plastic end, but it is usually white. Maybe a ruler along side would give us a scale to go by.
I believe the 80(or at least some of them) do have the accelerator pump. I don't have one on mine right now because I have carbs from a 78 on it but the set that came off of it has a pump. I think the o-ring for the pump is just a normal round ring though.
Flip the kidney shaped piece upside down and see if it fits. Looks like a bushing used for universal fit.
Could also be the nylon piece at the top of the velocity stack, but IIRC those were usually white.
I believe it's called the Nansensuson Disjointed Bushing. The Japanese characters that name it are so complicated that no computer has the capability to reproduce them.
Discussion Starter · #14 ·
Many thanks for your input fellas
I am now confident that it came out from under the cut-off diaphragn cover. Both carbs have exactly the same one and it does fit OK (the size in the pic, btw, is not to scale with the black banana - it is actually much smaller. I got the pic here ) I reckon the PO bought himself a refurb kit and used these because they sseemed to fit. I'll see how they go when I re-assemble tomorrow
If you look carefully, it has a flat side and a rounded side. The flat side goes into the recess for it and the rounded side goes to the cover.
Very well, I already have the title of Baron in another life.
Rusty
Shep nailed it with a picture. Several folks knew it is used in the cutoff valve portion of the carb.
I had a run-in with a Canadian bike parts vendor about this exact part. I ordered 4 cutoff valves (for 2 bikes). All the kits came without that little tiny part (it was pictured in their ad on eBay). It took over a MONTH for them to get me 4 little washers. In the meantime, I gave the vendor as many "BAD FEEDBACK" remarks in that they hadn't responded to me. I haven't done business with Sirius since.
I like the idea of having a BAD VENDOR STORY forum.
Russ from Danbury, CT
13 cx500's 78-81 Seven run. 6 in process.
We had started one on the old forum and for good Vendors like in the UK,
David Silvers
Wemoto
John Oldfield.
Motad 2 into 1 Exhausts
USA for me
Georgefix via Ebay.
1 - 19 of 19 Posts
