Hi all nice to see the new forum.
I have a few unrelated issues I thought I would ask about.
1. I lost the bolt that holds the gas tank down.. Do youknow what the thread is on that so I can go get another one.
2. What is the type of bulb that is used to light up the speedo/tach/ signals etc. I bought some at Autozone that look right and work.. But I would like to replace them with a compatible LED bulb if that is even an option. I have some resources for good LED bulbs but I need to know what the type is called.
3. The left turn signal indicator is lit SLIGHTLY even when its off.. Seems like if you put the signal on, then off it goes out.. but then slowly it light up again. I am guessing a ground problem in the switch but any other suggestions would be great.
Thanks for the help
Ken
Thanks for the help
Ken
