I have always considered the front markers to be parking lights, but calling them running lights is perfectly fine and I would consider them one and the same. The OP is perfectly fine not using these lights in the USA. Capping them and only using the turn signal wires is perfectly legal.
"Parking lights" are lights that you turn on so that drivers can see your parked car and not run into it. "Marker lights" or "running lights" are lights intended to make your vehicle more visible on the road. There is a big difference between these concepts.
And I think you will find that you are required to retain all lighting functions that the vehicle had originally. You may get away with not having the marker lights because some makes/models didn't have them and no cop could be expected to know which ones did but, why would anyone want to make their bike less safe by making it harder for other road users to tell what it is at night? Or give someone in a car an excuse to run into you and claim that they couldn't tell what your bike was or where it was on the road).
Not to mention that their lawyer could bring an expert to court to show that the bike didn't have the marker lights it came with and put the blame on you.
FWIW, I have turn signals that do not act as marker lights on both of my bikes but I also have separate marker lights.
'82: Welcome to the forum. Please add your location and your bike's model and model year to your profile so that you don't have to remember to tell us every time and we don't have to keep asking when you forget (see Forum Settings link in my signature).
