My '82 GL500 often won't crank when I press the starter button. When this happens, here are the symptoms:
1. When I press the starter button, the headlight dims
2. When I press the starter button, there is a subtle click down near the starter (NOT at the solenoid)
3. Sometimes squeezing the clutch and pressing the button will get it to crank, but not every time
4. If I attach the green/red wire from the solenoid to the negative terminal of the battery, then connect the yellow/red wire from the solenoid to the positive battery terminal, the engine will crank (this is the procedure suggested in the service manual)
5. Often after I employ the procedure in #4 above, just simply pressing the starter button on the handlebar will once again work fine. Until some critical moment on the road when it doesn't and I have to do #4 again.
I can rule out three things specifically: the battery is fully charged, the 4-pin connector at the solenoid is not an issue (as it has been replaced), and the fusible link is fine.
So, is this a starter issue, a solenoid issue, a starter button issue, or gnomes?
Thanks for your help!
