1 - 10 of 10 Posts
Hello, just picked up an 82 gl500. Right at 7,800 miles. It sat since 1998. Couldn't beat the price of $100. Not sure what I want to do with it yet, get it running first. The only problem...no key. Previous owner lost the key. Any quick advice?
Take out the ignition key ,two bolts from underneath and get a locksmith to cut a key to fit it. Do have to take fairing off or headlight to get at said bolts. Welcome
Discussion Starter #3
Thanks. No, the fairing is still on. I am planning on taking it off anyways.
Welcome to the forum. Please add your location to your profile and your bike's model and model year (NOT year first registered) to your signature so that you don't have to remember to tell us every time and we don't have to keep asking when you forget (see Forum Settings link in my signature).
The locks all have a number stamped into them that a locksmith should be able to cut a key based on but I don't think you can see the number on any of them without getting at the back and I can't think of a way to get at any of them without unlocking the lock except for the keyswitch.
Fortunately, removing the fairing isn't terribly hard (unless there are a lot of non-standard connections like mine has evolved to over the years). Basically, you unplug the electrical connector plus one other wire (green on the '82 IIRC) and undo a few nuts (it is covered in the FSM).
Depending on how skinny your hands are you might need to remove the tank to get at the connector and you will need to remove the front seat to get at the bolt for the tank and you may need to pop the side covers off to get at the bolts for the seat but removing the side covers, seat & tank to assess the condition of everything under them is probably a good idea anyway (I'd have a look at the air filter too, if only to make sure nothing has been living in it).
Welcome aboard! My '82 GL500 had 7,800 on the odometer when I got it 2 years ago!
I just took out my ignition to repair it. I had to take off the windshield and headlamp. The bolts are 10mm. Finding that on the tutorial helped me not fumble with sockets trying to find the right one. An extension on the ratchet helps you get in there. Be careful with the three prongs. Mine was soldered in so the black cap and white disc had to come out to release the keyed ignition switch. If you have to take the black cap off, Push in at the rectangular holes to release the prongs. A P.O. broke one of the prongs so they had to glue the cap on.
Good luck!
Since it has been out of service for so long, you will be removing the fairing anyway, remove the ignition cylinder as described. On the side of the cylinder is a stamped number. You can order a new key using that number from several sources on E-bay. yes it will take several days. You can use that time to check fluids and flush as needed. Also shop for some new tires since they are well past their service age. Relax and enjoy the experience.
You might want to clean and lube it while it is out. The photos in the link below will show you what everything looks like.
Get some tuner cleaner (I got electrical cleaner at the parts store) dielectric grease and some graphite or teflon dry lube for the lock mechanism. Here is a wiki link to see what it looks like. (see last two photos for the GL)
I did not have connectors to the round white switch. The wiring was soldered on.
Cleaning the Ignition Switch
1 - 10 of 10 Posts
