Hi everyone,
I have an '81 GL500 that I'm having a mystery issue with. Up until a month or so ago it was running like a champ, but then one morning while I was out on the road I was suddenly getting poor performance. Out of the blue, I could barely get any acceleration as it took time to even get it up to 40 mph even with high engine RPMs, was backfiring, with a funny smell from the exhaust. So far I changed the spark plugs, took the carburetors off, inspected them then went ahead with cleaning and rebuilding them using a Randakk kit, and I've cleaned and re-oiled the air filter. I tried test riding it yesterday and it was still accelerating poorly with erratic RPMs. Also it is no longer backfiring but the exhaust still smells funny. While I have the choke pulled out when cold-starting the engine the RPM is up around 3,000/min, however the choke as it is now seems to have little if any affect on the engine RPM although it will cause the engine to die after a few seconds with the choke pulled out. Even with it pulled out upon startup I still need to keep cranking the throttle to keep the engine going.
I'm at a bit of a loss at this point what could suddenly cause all these problems and why it's so hard to trace down. I hope my symptom description made sense. I feel like I'm grasping for straws at this point and any help and/or suggestions would be greatly appreciated!
Thanks!
David
Thanks!
David
