I'm pretty much down to paint now but I figured I'd start a thread anyways. This is my 81 CX500 with 06 Honda CBR 600rr front end.
Other completed mods:
Todo:
- subframe replaced with rejuve motorcycles monoshock kit and bobber seat
- New custom wiring harness as all electronics are now under the tank on a dabbed bracket or in battery box (I think may be made by a forum member of anyone knows, I'll update this)
- nuut tricky control unit
- rae-san hall effect ignition
- new ignition coils
- Murray's upgraded reg/rect
- shorai 8 cell lithium battery
- new starter solenoid
- 2 button controls
- led headlightand bracket
- choke relocation bracket
- license plate lights and bracket
- Murray's midpipes, 12" reverse cones, 8" packed baffles, custom brackets
- under seat turn and brake signals
- clip ons and controls
- pod filters
- tank relocation bracket
- ignition switch in head tube
- engine paint
- rejuve radiator cover
- custom adapters to mount 5 bolt rotors to constant (I'll update this with the model)
- custom axle spacers
- wheel bearings (if you use 07+ forms I believe you get a 20mm axle which are easier to find bearings for)
- steel brake lines
- head bearings
Todo:
- bobbed front fender
- muffler wrap
- better speedometer
- paint
- custom overflow bottle
