1 - 12 of 12 Posts
Hi everyone,
New Member....I'm at the end of a long build and I need to replace my fork seals but every service manual has a different fork than is on the 81 cx500D and I can not for the life of me figure out how to take them apart, if someone can direct me to a service guide or has any info on how to take these forks apart I would appreciate it
Thank you for taking the time to read this
Hi everyone,
How to take apart the forks or how to remove them? How far into it are you?
I have them removed, the top unscrewed, the large spring removed, the half moon locking washer thing removed but can't separate it from there
Cant get the hex head bolt out of the bottom that holds it all together?
finally got everything apart and now can't get the new fork seal to go back in, is there a technique or do I have have a special tool?
Get everything in place (bushings), then push your fork seal down so that its ready to be seated. You can uses a fork seal driver, I use a piece of PVC pipe of the right diameter (I think it's 1.5 inch off the top of my head, about 4 feet long). Use it to seat your seal by tapping it with a mallet, doesn't take a lot of force once you're using it. Then install circlip.
Thank you , I'll go give that a try right now, are the seals supposed to be very lightly bigger than the old ones that came out? from compression?
I typically rim a smidgen of fork oil on the outside of the seals, they go in a little better. They should fit in the top of the slider with finger pressure, but you shouldn't be able to push them in without a tool or PVC.
I just ordered another new set, these are far too big, just ruined one and compared the and they are quite a bit bigger.......rrrrrrr
Thanks for the info, I really do appreciate it!
Just ordered another set, these are too big and I just noticed they the bottom of them look different......rrrrrr..
Thank you very much for the info, I really appreciate it
1 - 12 of 12 Posts
