1 - 20 of 99 Posts
Last fall I brought her home looking like this...I paid $600, 17k mi., garage kept (mostly), and new Hondaline oil EVERY year!
I have a HUGE pile of parts waiting... and so it begins.
Nice clean bike, you got a good deal. While I hate to see such a fine example of that bike get tore apart and customized, I wish you the best with your build and have a great time doing it.
Ok, keeping the thread alive... Deadbeat Customs Tail light, seat (from Vietnam), and Kenda Big Block tires.
Those are a few of the recent additions to the parts gathering in my garage...
I had no desire to own this bike in the condition I found it... I bought it as a canvas for my custom build.
I rode it exactly 35 miles to prove mechanical function, then the tear down began.
The Samsonite luggage, and Vetter Fairing were given away on my curb (with a HUGE FREE sign)
This is the closest build I can find to my idea... the main difference being; I will leave the fenders full length, and my seat will be long enough to accommodate 2up.
Today I ordered new wheel bearings (for when I powdercoat my wheels). I already received a 1980 GL1100 rear 17' wheel from eBay. It's in great shape, I'm ripping it apart, and doing the frankenwheel conversion with my stock CX500 center unit. And I ordered a complete front brake caliper/hose/master setup from a 1982 Ascot. That has the newer dual piston caliper, the stock CX500 single piston one piston is pretty lame.
They were spendy, but the quality, and brightness makes it seem worthwhile.
All in one multi gauge / micro horn, Shorai Li-Fe compact battery, and a pic of my donor wheel for the Frankenwheel conversion.
I have delivery trucks stopping by almost every day...
I am aware, my build is in it's infancy, and there are some DAMN FINE builds in the "completed build" section...
But, I have been doing my research / developing my opinions of this build direction for over a year, and I hope all of you on CX500 Forum will appreciate this build once it really gets rolling...
I have equipment to Cerakote, and Powdercoat in my shop. I also just got a 2 year welding degree, at my local community college.
So, I am open to suggestion/ critique from you few people on this earth who have a deep understanding of the CX500.
Discussion Starter · #11 · (Edited)
That hybrid wheel (Goldwing 17" rim-spokes/CX500 hub/drive) build was a bit time consuming, but the outcome was fantastic ! I'm loving where this is headed. I've only been powdercoating a couple of weeks, it is turning out amazing...
I got my twin piston caliper, wheel bearings, brake pads & shoes, headset bearings, and fork seals. While I wait for the "slow boat from Vietnam" to deliver my seat... I am prepping more parts for powder coating. I blasted the rear brake backing plate, and drive unit. I will coat them, and a few other small items in the next few days, pics to follow...
Looking good. What is your powder coating setup?
Discussion Starter · #14 ·
I bought the Eastwood "Dual-Voltage" gun. I have been Cerakoting for a few years, so I just added an additional heating element to my oven, to hit the higher temperature needed to cure powder coating. My oven is a Diamond plate truck box up on end, so the door opens like a fridge, it's wrapped in ducting insulation. I used a Presto pancake griddle as a heat source before, but that only reached about 305 F, which was adequate for Cerakote. Now I use that as a base heat, and an added 110v stove element w/PID controller that takes over from there, up to just over 400 F. My 17" rear wheel BARELY fit in there... My 19" front wheel will NOT fit, so today I am cutting the truck box open, and doing some sheet metal work. I plan to add around 8-10" in depth, so I could fit 2 LARGE wheels at once, like 22"x10"s.
Discussion Starter · #15 ·
I just had 4 days off... Spent most of my spare time rebuilding/expanding my powdercoating oven.
I managed to coat a few small parts doing a trial run temperature experiment...
Only a little progress this week... my stock shocks were dull chrome with slight surface rust. NOT any more ! The Faraday effect really kept much powder from reaching the inner tubes, but I think they look ALOT better than before.
Discussion Starter · #19 · (Edited)
Ok, I worked a lot of hours the last couple weeks, very little progress on this build... But a little has happened. I got Murray's mid-pipes, and quick-set tool.
I had my Hayabusa OEM mufflers in the rafters of my shop, my CX500 megaphones were in fantastic shape, except the end caps were rusty.
I salvaged the stainless tips from the Hayabusa, got a small section of 2 1/4" exhaust pipe from local muffler shop, and made custom secondary baffles.
I will Cerakote the entire exhaust Graphite Black.
I will tig weld it all together, with Kaowool in the baffle. I can't wait to hear how this experiment sounds...
Murray was great to deal with, his parts came quickly, and he answered my questions promptly.
I will order his carbs later this week.
Discussion Starter · #20 ·
Almost forgot, my headlight bulb came too! I watched a long review of LED replacement bulbs, this bulb rated very well. $47... after shipping.
1 - 20 of 99 Posts
