1 - 10 of 10 Posts
So I have connected the little Acewell to my bike, ordered with a new temperature sender and adapter. With the new adapter and instrument do I need the 7V regulator up front anymore? It's the Murray updated one, installed by previous owner.
199437
Wait for an answer from someone that has installed one but I think the answer is no, you won't need the 7 volt reg.
I think I have the same acewell on a CX I have here, but it came here half built and still sits exactly as it arrived. IE - I didn't wire it.
Discussion Starter #3
Thanks! All input is appreciated :)
I guess the loose ends of the wires needs to be cut, connected or something else?
It has a black wire in. This is switched 12 volt from the key switch. If you don't need this power supply terminate it or cap it off as a spare.
The green and yellow wires belong to the 7 volt reg and will just be removed with the reg.
If the 7 volt reg is required the yellow connects to the instrument supplying said 7 volts.
The green is simply a ground.
Discussion Starter #5
Thanks a lot, I'll use the black wire for the instrument backlight I guess. Thanks again!
The instrument back light will be on all the time the key is turned on if you do that.
Another choice is tapping into the bikes blue/white or one of the brown wires. The blue/white will bring the instrument lights on with the headlight and I think the brown will too. Not sure about the brown ....
A test light or multi meter will tell you which goes live in which switch position.
Discussion Starter #7
It's mandatory to have daylight running lights on at all times here in Norway anyway, so the headlamp is always on. Since I'm relocating the battery and running a smaller battery I was thinking about leds all around to lover the overall pull.
1 - 10 of 10 Posts
