1 - 11 of 11 Posts
Hey all! I've searched my way around a good bit gathering what info I can on swapping out front and rear ends of my '80 CX500C with my '79 GL1000. Checking to see if anyone can clarify a couple things for me?
From what i can tell, the front end is fairly straight forward, use appropriate All Balls bearings and good to go, no fabrication. Is this impression correct?
Next, for a rear swap, we'd be looking at some break caliper mounting fab as well as a spacer. Otherwise, the final drive will bolt up. Is this correct?
That's all I got!
Thanks for the look and help.
Pat
You'll need to shim the CX500's rear axle to hold the GL1000's wheel. Bearings with the CX ID and GL OD aren't readily available.
There will also be some interference between the final drive's dust shield and a flange on the wheel hub. I've started to explore modifying or swapping the dust shield, but it doesn't look promising. Usually, the flange gets machined off of the hub.
OK, so the rear end is a bit more involved. Perhaps a sleeve to make up for the difference in the barrings? And, looks like I was confused, I'd keep the CX final drive and need to modify the gl1000 hub to make this work. Machining the hub is doable!
Yes to keeping the CX final drive. That's why you need to use the CX axle.
... and need to modify the gl1000 hub to make this work.
This is what the shim/sleeve is for, at both the bearings and the brake caliper.
You might also need a custom spacer between the wheel bearing and final drive. I haven't looked at it for a while.
Got it, all pretty doable it seems. Would you happen to know if this would work with a GL1100 wheel as well?
Not sure. I was setting up for a spoked wheel. If they use the same bearings and the final drive is compatible, it should work.
That said, the GL1000 is not a bike known for great handling so changing to GL1000 forks probably won't do much except increase the weight your engine has to push around. Add in that the GoldWing's rear wheel & tire might be a tight fit in the CX swingarm and this sounds a lot like it may make the bike work less well after all that effort.
79 CX500, 80 CX500
I am actually in the process of doing this myself, for the front end the triple tree stem on the GL1000 is slightly longer but in all other respects are exactly the same. The All balls bearing set for the CX500 is a direct fit for the 76' GL1000 Stem all that is required is a spacer to be created to lift the bottom bearing off the bottom brace, don't quote me, don't have my measurement in front of me but I seem to remember it is something like 3/8 or 5/8 spacer is all that is required. Additionally, some tabs will need to be removed from the CX500 frame to allow for clearance. I Will attempt to upload pics if that would help, let me know.
On the rear end, I am still investigating the conversion, in my case, I am attempting to use the entire rear swingarm, wheel (wire wheel from 76'), disc brakes, and final drive from a 76' GL1000. A couple of considerations for my setup, the final drive gearing will be different (basically resulting in the lower top end, faster acceleration) the rear swingarms between the CX500 and GL1000 are different lengths. The CX has a length of 19" from pivot to center of the wheel (axle) whereas the GL1000 has a measurement of 18", then there is the width of the swingarms to consider (this is where I am currently) the CX swingarm is considerably smaller than the GL swingarm which measures 11 inches this barely fits between the frame. Best guess at this time is that I should be able to make work.
Good luck with your project
using the gl1000 front end a rear wheel is a quick cheap way of getting spokes
You know how I feel about wire spokes. I've retired too many wheels because of broken or badly rusted spokes and gone too many Km/miles on Comstars with no problems to ever consider wire spokes an improvement.
1 - 11 of 11 Posts
