1 - 12 of 12 Posts
Let me start by saying I have done some looking around beforehand and as far as I know I do not have a 80+ ignition (previous owner says it used to work just fine before it got torn down)
My current issue is that every time I turn the key to Park it blows the main fuse. I have tried unplugging everything that should be active in park and it still does it. With some digging around I found a wiring diagram and on that diagram it shows which circuits should be active and in which position
207609
I disconnected my ignition and wrote down which pins were connected to which wires and then did a continuity check on all pins in all positions to see if they lined up with the diagram.
207610
It kind of followed the diagram but there were a few differences in On and Park.
207612
As for Park, the issue I believe is that it shorts Red (which is(+)) to Green (which is chassis ground), which is obviously enough to blow a fuse instantly.
207613
Is this a case of somebody rearranging the wires in the connector or do I have a bad ignition or did the previous owner replace the ignition and never turn it to Park?
207617
Here's the proper CDI switch pin out.
These are the positions that the terminals should connect in.
Red - on.
Blue - park.
Black - off and lock.
A CDI switch hooks black/white to green in off and park to kill the CDI system.
Unfortunately, I've recorded nothing about the brown/white for some reason.
Pretty sure you have the wrong switch.
Red - on.
Blue - park.
Alright thanks for the help! I'll have to start looking through ebay and find the right one
Niche cycles used to sell the correct CDI switch. Ebay listings tell lies about the fitment of these switches often listing as 78 - 82 when they are only correct for the 82. Be wary.
Hard to say but the eBay listing I bought from has (visually) the same ignition and key as the one on Niche Cycles. I guess we’ll find out in 3-5 days!
Did CX500s have an aux position? North American CX500s didn't have park position as far as I know.
My '78 has Park.
This is the stock cylinder with an aftermarket base installed a few years ago. George Fix (on eBay) didn't have the right one in stock, so he directed me to a seller who did. Good guy!
It looks like 4-into-1 has the correct part.
Thanks for the link! I guess someone's watching out for me because that's who I ordered from earlier!
What they said^^^^^
BTW: Welcome to the forum. Please add your location and your bike's model and model year to your profile so that you don't have to remember to tell us every time and we don't have to keep asking when you forget (see Forum Settings link in my signature).
1 - 12 of 12 Posts
