Backstory:
I got my first CX500 a couple weeks ago. 15k miles. Previous owner hadn’t ridden it for a year due to electrical problems. I found and fixed the broken wire (main 20A fuse wire was chafed). Motor idled really well after a car rebuild.
Took it out for a ride, motor seized at 0.9 miles. Luckily I didn’t crash. Only left a nice 10 foot skid mark. No idea what caused it to seize. Took it apart, mechanically looks fine, but looked like it jumped timing.
I found a motor locally that was included with a running CX500. The motor had been sitting for years, but was claimed to have been a runner beforehand. It was seized from sitting.
I ohmed out the stator coils, they all checked good. Poured some MMO into the spark plug holes, let it sit for a day. It broke free easily. I verified that valve timing looked good and installed it into the bike.
Considering that the bike ran before all this, I assume that the CDI unit & ignition coils are good. When I crank the engine it has spark.
I can’t get it to start however. It will very rarely make any sign of combustion. Sometimes I’ll get a blue flame out the exhaust port rarely (no exhaust installed at the moment).
I verified ignition timing with a timing light. I swapped over the CDI from my running bike. I tried starting it with the yellow alternator wires disconnected as well.
I’m at a loss here. All I can think of is that either the engine has 0 compression (my compression tester won’t fit, I’ve ordered one), or that the spark from the CDI has suddenly become too weak.
The speed at which it cranks is similar to that of my running bike. It definitely feels like there’s compression via the thumb test.
To sum it up, previously time-seized engine has spark, starting fluid/good carbs but won’t run.
