I haven't tried them on the 650, but I suspect HD takeoffs might be a good replacement.
Most harley's being over 1200cc, are you saying one muffler for both cylinders?I haven't tried them on the 650, but I suspect HD takeoffs might be a good replacement.
what pipes does murray recommend with his carbs?Usually a pair. Older Dynas are a good choice, but getting harder to find.
Used with the stock h-box, too free-breathing isn't a concern. Might need re-jetting with the mid-pipes.
im trying to do the opposite lol. im putting a 650 in a 500 frame.Surprised not to see SidecarBob in this thread. He put a 500 in a GL650 He might have some insights.
It would seem that one could inform the other.im trying to do the opposite lol. im putting a 650 in a 500 frame.
apples, oranges, bananas. Cx/GL/turbo. This thread is all over the placeIt would seem that one could inform the other.
meh. its in the general discussion for a reason. ive gotten a bunch of useful info already.apples, oranges, bananas. Cx/GL/turbo. This thread is all over the place
I'm it is still a bit varied/confusingmeh. its in the general discussion for a reason. ive gotten a bunch of useful info already.
Bob was working with GL and Eurosport frames. They're close enough to identical that the engine was almost a direct bolt-on.im trying to do the opposite lol. im putting a 650 in a 500 frame.
I believe it was Gerard who recently put a GL650 engine into his GL500. Here again, there was no CX500 frame involved, so it was almost a direct replacement.
It's the single- vs triple-spine frame that necessitates all the adaptation.
You're in new territory, there.And I'm doing a CX650c into a Turbo 500 frame;
According to the respective FSMs, both the GL650 and '78 CX500 use 35mm carbs. My first attempt will be to mount a pair from a '78 CX. I think it was Charles who said the CX500 stock isolators can work on the 650 engine. Maybe I'll need to adjust the brackets and transfer pipes a little. I think that would be easier than straightening and spacing the 650 carbs. It might be easier still to 3D print custom intakes, assuming the ASA I'd use could take the heat.@Randall-in-Mpls The only thing off the top of my head for @SirFoxx to worry about is the carb body issue; where the 650 carbs need the space the 500 frame takes up, the 500 carbs being spaced to the outside of that.
I'm tempted to use the CX500 radiator with a GL1200 cooling fan (the one with the flat motor) that I have on hand. That would mean less modification to the engine hanger. I'll need to mock that up before deciding.And the radiator return area is different on the 500 from 650. Was there more?
Which is exactly why I didn't post in this thread sooner.Bob was working with GL and Eurosport frames. They're close enough to identical that the engine was almost a direct bolt-on.
I did the 650 swap into an 82 cx500 way back in 2004. I used the stock cx radiator and a cbr electric fan on a modified hanger bracket. Cx carbs and stock air box.Which is exactly why I didn't post in this thread sooner.
BTW: I was among the first on the forums to put a 650 engine (actually from a CX650E) into a GL500. At the time there was very little knowledge about what was required and there was even some speculation that it might not fit or the frame and drivetrain might not be strong enough. I had to us the 650 carbs & intake runners because the 500 ones wouldn't line up with the 650 and the 650 airbox because the boots between airbox and carbs are completely different but it turned out that the biggest issues were that I would have to modify the GL500's rad's mounting lugs beyond what I considered reasonable to make it fit the 650 hangers (I went back and bought the 650 rad) and that I had to put the 500 engine's final shaft into the 650 so that it would mate with the GL500's u-joint (the GL650 uses the same final shaft as the GL500 so this is only necessary if you have a CX650E or CX650C engine).
And about a year later the camchain broke and I ended up putting the 500 engine &c back into it.
15 years later I found myself putting a GL500 engine into what had started life as a CX650E. I had replaced the original rear end with a GL500 swingarm & driveshaft, CX500 final drive & wheel and a brake with CX and GL500 parts when I first got the 650 (& installed a 500 final shaft in the original 650 engine) and the rad and electric fan are neither stock or in the original location so that wasn't an issue. I think spent more time on cleaning & painting things than I did actually taking one engine out and putting the other one in. You can read about it here
Eccles: The Never Ending Build (retroactive to 2006)
It looks like I finished messing with Eccles just in time. Mr.H's biggest problem is that the combination of a GL1000 engine (& transmission) and a GL1100 final drive results in gearing that is a little higher in 1st than the stock combination is in 2nd (great on 2 wheels but too high with a...www.cx500forum.com
the bad part of that is you don't get the honda OEM rad fan switch IMO the best way of controlling the fan all else is fiddly and does not work as well or as long as the direct control switch in the 650 rad or the gl 4 cylinder direct contact controller that is designed to handle the full amperage draw of the fan for years and yearsAccording to the respective FSMs, both the GL650 and '78 CX500 use 35mm carbs. My first attempt will be to mount a pair from a '78 CX. I think it was Charles who said the CX500 stock isolators can work on the 650 engine. Maybe I'll need to adjust the brackets and transfer pipes a little. I think that would be easier than straightening and spacing the 650 carbs. It might be easier still to 3D print custom intakes, assuming the ASA I'd use could take the heat.
I don't think that will work very well. I know the GL500 runners & carbs won't line up with the 650 engine (& vise versa) so I doubt the CX500 ones will work either.According to the respective FSMs, both the GL650 and '78 CX500 use 35mm carbs. My first attempt will be to mount a pair from a '78 CX. I think it was Charles who said the CX500 stock isolators can work on the 650 engine. Maybe I'll need to adjust the brackets and transfer pipes a little. I think that would be easier than straightening and spacing the 650 carbs. It might be easier still to 3D print custom intakes, assuming the ASA I'd use could take the heat.
