No. He's not using a GL500 frame. He needs to modify the hanger that fits his CX500.
No. He's not using a GL500 frame. He needs to modify the hanger that fits his CX500.@Randall-in-Mpls So @SirFoxx could order these and they'd be a bolt in solution?
83 HONDA GL650 GL 650 SILVERWING ENGINE MOUNT BRACKETS #U21 | eBay
83 GL650 Engine mounts. Part is in good working condition. Any problems will be stated below. (11161) (4).www.ebay.com
i think my cx500 is vented through the cylinder head, though i'll have to check. its been awhile since ive looked under the covers.Depending on the year of the engine the crankcase may be vented through the cylinder heads, CX500s, through the pulser cover, GL500 and others, and through a bottle breather at the timing inspection port.
@SirFoxx Do you still have the valve covers from the 78? @Molten Stenberg cracked one of his and was looking for a set. Any set really.i think my cx500 is vented through the cylinder head, though i'll have to check. its been awhile since ive looked under the covers.
before you say the '78 didnt have X style, i had to swap an '80 engine onto the frame after i locked the '78 engine up...
I know the gl650's that i have use the bottle breathers.
ok, so it needs to be m6x1.0 to m8x1.0? just want to make sureNote that these are M6x1.0 to M8x1.0. The common adapter is M8x1.25.![]()
Maslin M6 to M8 Inner and Outer Threaded Hollow Tube Adapter Inner Outer Threaded Coupler Conveyer Adapter - (Color: Zinc Plating, Size: M6 to m8 Pitch1.0, Thread Specification: 10 Pieces): Amazon.com: Industrial & Scientific
Maslin M6 to M8 Inner and Outer Threaded Hollow Tube Adapter Inner Outer Threaded Coupler Conveyer Adapter - (Color: Zinc Plating, Size: M6 to m8 Pitch1.0, Thread Specification: 10 Pieces): Amazon.com: Industrial & Scientificwww.amazon.com
nope. the engine got scrapped about 6 years ago.@SirFoxx Do you still have the valve covers from the 78? @Molten Stenberg cracked one of his and was looking for a set. Any set really.
Correct.ok, so it needs to be m6x1.0 to m8x1.0? just want to make sure
Bottle Breather and the vented pulser cover.I know the gl650's that i have use the bottle breathers.
reclamation system..?Bottle Breather and the vented pulser cover.
The bottle on the inspection port is really to increase condensation of vaporized oil before it passes to the reclamation system. It's a secondary vent, at most.
oh. my cx500 is just venting to the atmosphere lol. i think i have one of the hoses still hooked up tho.OIl vapors and moisture from the crankcase are directed to a collector under the air filter housing. The volitiles are pulled in with combustion air and burned. The heavier junk, including water, is retained and drained at each oil change (if you're doing your proper maintenance.) The GLs have a more elaborate separator and reservoir. I believe the bottle is intended to help separate the oil vapor and return it to the crankcase.
where are you supposed to run it to with murray carbs?I hope it doesn't vent directly to atmosphere, or you're sucking in dust and contaminating your oil.
If you have hoses, but no collector, you're leaving a trail of oil drips somewhere.
i dont think the average schmoe who buys his kit acutally routes the crankcase vent to the suitable placeA filtered catchcan/separator might just work...
You can buy suitable pod filters for the application.
I did. Get a long hose and put a small filter on the end of it. Route the hose between the "V". It's so long that oil vapor will never make it to the filter, but that doesn't keep the engine from breathing properly.i dont think the average schmoe who buys his kit acutally routes the crankcase vent to the suitable place
gotcha. what would a be a decent set of mufflers to use? I currently have emgos on my cx500, and i think theyd be a bit restrictive as well for the 650500cc headers have a smaller internal diameter and will choke the 650 motor. The 650 headers are also longer to accommodate the extra height of the cylinder heads. While you can use 500 headers, you will be down on power (I verified this by accident) and your collector will point downwards at the back, causing your mufflers to not line up with their mounting brackets.
Charles.
