the 650's, cx or gl, will drop onto the 500 frames with a modified 500 stamped steel hanger. you cannot modify the gl hangers as they are cast.
there are 4 bolts that hold the hanger to the motor. I believe the lower set needs to get modified--you cut the collar that the bolts go through off the mount, get new collars and move them down like a 1/4" and reweld them. its a very simple process. the reason for doing this is because the upper part of the mount that bolts to the frame is very different between the 500's and the 650's.
