1 - 3 of 3 Posts
OK, somebody 'splain to me how a 650 clutch in a 500 will reduce the RPM's.
I can't get my head around it and so it's time to ask!
The gear on the clutch basket meshes with the gear on the crankshaft to form the primary reduction ratio. the 650 has a higher primary (36/74 is 2.056:1)compared to the 500(33/74 is 2.242:1) so revs lower per given engine RPM. If you want to see what gearing does what, supply me with a email address and I will send you a simple excel program I wrote that shows the effect of changing any gear, or tyre size to engine rpm, per 1000rpm in all gears.
I did it and believe me it is different. It's like having a 5 1/2 gear. Infact now if I need I can sit in 4th gear even longer and when I shift into 5th the rpms are way down.
I hate mechanical gauges but I can tell you what i'm seeing. Instead of being 500rpms behind the speed.
ex.. 6500rpm's = 70mph.
Now imagine this.
at 6500rpm's i'm doing 80mph.
The only precise way for me to know would be to borrow a gps and maybe pick up a electronic tach but i'm not that concerned.
1 - 3 of 3 Posts
