1 - 9 of 9 Posts
CX500 Turbo, Suzuki GT750 fuel injected triple special, Triumph Tiger 1200, Beta 300RR
Has anyone got a clean 500T wiring diagram. My pdf service manual is hard to read.
I think my 7v (meter gauges) regulator has taken a dump but cant see the wiring colours to tracce it.
I guess it is behind the instrument cluster?
Discussion Starter · #2 ·
Ah! I think I found regulator. Is it under the speedo? From what I can see from the wiring a simple test is to probe the thermostat wire which should read 7v (mine reads 0v).
How do I get to it? Headlight out?
A wiring diagram will still help if anyone has one please :)
So i've searched but can find if there is an easy way to get at the 7v regulator?
My poor resolution service manual shows the whole panel coming out once the left and right hand dashboard panels come out then the whole cluster has 4 bolts holding it in. Sound right?
It is simple. Unscrew the 2 bolts from the front hood next to the mirrors, turn the hood over, and voila there is the 7 volts regulator on the back of the teller unit.
Thanks. I saw they were in the US so shipping/import will add a bit. I am in UK
I am OK with electronics so I spend the day testing and digging out the old regulator. I also checked the current flow required to power both gauges and its about 250ma, so not a lot.
A standard L7805 regulator will power it and I saw the post about adjusting the output voltage to 7v using a LED as a ground bias. I don't trust LED's long term too much (lots of cheap Chinese copies about) so I have designed a circuit that will fit in the original box. Will post pics etc. when its all done.
Thanks for the pointers.
1 - 9 of 9 Posts
