Hello all,
I am a new member here, I've been riding for exactly one year, and am starting to do more involved work on the bike. One of my front forks has been leaking oil for a couple months. I've done research on this forum and others to see the steps and took a shot at it myself last weekend, but as always, doing the actual work is more challenging than reading the instructions.
In the process of attempting to loosen the fork tube caps (the ones containing the schrader valves), I stripped the hex structure (part of the cap itself) that is grabbed to twist and remove the cap. It may have some sort of grip yet, but it is pretty badly stripped. Does anyone have any advice as how to remove this cap?
Someone has recommended biting into the (aluminum?) metal with a chisel to loosen it. Another recommendation was to use vicegrips if I can get a grip. I have yet to attempt either way.
Also where do you guys mainly get your parts for things like this, (a new fork tube cap, for example) I've been using bikebandit so far, but I get the feeling it is pretty pricey.
Thank you guys for your help,
Christopher
1983 Honda cx650c
Learning as I go
Christopher
1983 Honda cx650c
Learning as I go
