1 - 2 of 2 Posts
I just bought a 1982 GL500, everything worked perfectly... I removed the toolbox and the left rear turn signal came loose. I rewired the turn signal and now none of the turn signals work and the headlight does not turn on. The brake/tail light still work. I replaced all fuses, checked for loose grounds and cleaned all the connections and switches. Still nothing. Perhaps I'm not finding a loose ground? Please someone help! Any suggestions will be most appreciated!
You should have an orange and a green wire for left rear and a blue (light Blue?) and a green for right rear. Greens are grounds.
here is a wiring diagram for the GL500
http://cx500forum.com/mediawiki/images/0/05/1982CX500C_81-82_GL500_schematic.JPG
Make sure all your bulbs are good. check the front connections as well as the rear's are routed from main harness at front. Sounds like you lost a ground some where
1 - 2 of 2 Posts
