Northern Virginia: 1982 GL500 rear suspension modified with Yamaha shocks. CA: 1981 CX500 custom
Hi all,
Nasty issue that's been preventing me from riding -
Initial issue - front clamps occasionally lock up, loosening the bleed nipple helps.
  • Rebuilt caliper with parts from brakemasters, including new pistons and new seals, still locks up occasionally.
  • replaced brake hose with NOS brakehose from Japan - still locks up
  • the previous owner just replaced the reservoir so that's also new.
Current situation: the brake is dragging - front wheel cannot complete one revolution when spin by hand and lifted off the ground.
suspected issue: master cylinder act in a "check valve" fashion, because when I took the caliper off, and try to press the pistons back it won't buldge, even with a C-clamp.
The Caliper even made a dent on my brand new C-Clamp without the piston ever retreating (caliper not bled).
Photos show how hard the C-clamp worked...
But before I rebuild the entire master cylinder....I wanted to get a second opinion on what this could potentially be - to avoid making the previous mistake of rebuilding the front caliper at least 3 times without zero in on the problems first....
Appreciate any help!
Auto part Tool Metal Titanium Circle
Automotive tire Motor vehicle Automotive lighting Rim Automotive wheel system
White Light Blue Azure Purple
Reactions: Randall-in-Mpls
