Hello everyone. New to the forum. Not at all new to riding or turning wrenches on motorbikes. I bought a 1982 CX500 Custom with about 29k miles for $200. It sat in a basement without running for about 5 years. When I bought it a year ago I cleaned the fuel tank, replaced the fuel petcock, put a new battery in it and then moved on to other projects. Now it's time to get this old girl back into running shape.
It would run when I bought it, but not well. It would intermittently only run on the right cylinder. After spending some time chasing electrical causes, I discovered it was just a bit of trash in the left carb causing the problem.
Since I figured that out and got it running well, I replaced front brake master cylinder, pads and disc (good condition used), rear brake shoes, tires, motor oil/filter, final drive oil, coolant, air filter, tires, adjusted the cam chain tensioner and the valves. It starts, runs, idles, charges the battery, stops, cools, all the blinkers and gauges work. Gotta love Honda build quality.
The goal for this bike is just to ride to work and putt around town a bit. I'm not dragging knees these days. I'm not into the cafe racer or scrambler look. And I'm not gonna do the work required to put this bike back in showroom condition. It's not in pristine shape. It's got a few minor dents on the tank. Not sure if the paint is original. And it's got a fair amount of rust on the exhaust, handlebars and other chrome bits. I hated the swept back handlebars that came on the bike (very early 80s Harley Sportster looking) so I bought a used set of bars from a CX500 that are more of the standard riding profile. From the same Ebay seller I bought a new seat to replace the King and Queen style saddle it came with as well as some Hondaline engine guards. I'll get it in good running condition, remove as much of the rust as I can and give it a good cosmetic cleanup.
I have a few questions as I move forward with the rehab:
1) The front forks are shot. They rock madly while going through the gears and will bottom out at the slightest hint of front brake, There's no fluid leaking around the seals, but I suspect that's because there isn't any left. I'm going to pull the tubes apart soon to redo the seals. I've seen on the forum that its possible to put a pvc spacer in to increase preload, or there are various replacement spring options. Anyone have any suggestions on how to rebuild the forks that will give a nice firm feel and account for my 210lbs? I don't mind spending a bit of money since I got the bike so cheap.
2) Is it worth replacing the rear shocks? I see some cheap options on Ebay...are any of these worth it?
3) Are the rear turn signal lights supposed to stay on while the bike is running? Or do they only light when signaling? My front turn signals stay lit while running and blink when signaling, but the rears only light while signaling.
4) The replacement handlebar I put on is a few inches shorter than the one that the bike came with. This means that the throttle cables, clutch cable and brake line are all longer than they need to be and have an extra bend in them. With some careful adjustment and lubrication I've got them useable for now but the have more friction than they should. I want to order all new cables and a braided brakes line. I've never replaced cables with a different length. Any tips on how to measure for this? Are cables measured by the housing or the cable itself? Any good vendors to buy custom cables from?
I have a few other questions but I'll leave at this for now. Any tips or advice you have is greatly appreciated.
