Hey Everyone,
I'm relatively new to this forum, i just bought a 1981 gl500 in running condition, minimal body rust, about 98% stock parts. I want to get this bad boy in optimal running condition. Oil looks clean and Air filter is clean. Since i bought it i've replaced the spark plugs, starter solenoid, rust treatment/cleaned the gas tank and fuel petcock, installed a fuel filter, i did sort of an incomplete carb clean where i just sprayed them out with carb cleaner got most of the grime out but the bottom of the float bowls still have some build up.
ISSUES:
*there is also a leak on the left fork, i'm waiting for seals i bought to come in then i will replace them on both forks and new ATF.
*The bike starts and runs, but there is some popping and occasional backfire, and above 5000 rpm the power just isn't there. I'm thinking to do a full carb clean (soak all the parts) when i get the replacement gaskets, and resync, as well as mixture adjustment, to see if this resolves the issue. any other suggestions?
*also i need new tires, i wouldn't want to take the pair i have over 45-50mph, any tire suggestions? i mainly use the bike to commute to work and school.
I'm looking forward to getting this running in tip top shape. I'll upload some pictures when i find my camera.
Thanks
ISSUES:
Thanks
