1 - 20 of 283 Posts
Thought I'd start a thread for my bike, as have spent countless hours looking at others.
Bear in mind, I'm a complete n00b, have done basic bits with cars over the years, but nothing on bikes.
I previously owned a Honda Rebel 125 and then a ZZR - now wanting something a tad calmer with a more relaxed seating position.
Land vehicle Vehicle Motorcycle Car Motorcycle fairing
I started with a 1978 CX500 in May 2015.
Land vehicle Vehicle Motorcycle Car Motor vehicle
Which fast became a frame.
http://i.imgur.com/vu8aHyR.jpg
I then spent a great deal of time polishing bits, both by hand and with a dremel.
Then either getting bits powder coated or hand painting with Hammerite black (to save money).
Land vehicle Vehicle Tire Automotive tire Motorcycle
Spent some time in the evenings after work polishing the engine block.
Engine Motor vehicle Auto part Automotive engine part Automotive design
Engine Auto part Automotive engine part Motor vehicle Carburetor
Land vehicle Vehicle Motorcycle Motor vehicle Automotive tire
Kept going on the bike until I got to about here...
Land vehicle Vehicle Motorcycle Motor vehicle Car
At this point, after several letters/forms/phone calls/emails etc etc with the DVLA, my only option for registering it was on a Q plate and having to pass an IVA.
Just having on the Q plate would reduce the value of the bike and passing the IVA could be interesting.
So decided to grab a doner / new bike. So after a 6 hour drive in a hired van. I had CX500 v2 (now with added V5).
Land vehicle Vehicle Car Motorcycle Motor vehicle
This again.. fast became a frame.
Land vehicle Vehicle Spoke Tire Automotive tire
This time, decided if I was going to go through all this again, I would "do it right".
Had a rear loop welded in and had several rusty parts of the frame repaired.
Automotive exterior Vehicle
Then had it powder coated and started transferring bits over.
Motor vehicle Vehicle Bicycle wheel Auto part Bicycle part
Have since cut down the rear mudguard and (roughly) mounted a headlight.
Tire Automotive tire Vehicle Bicycle wheel Wheel
Getting an idea of how its going to look.
Land vehicle Vehicle Motorcycle Automotive tire Tire
Discussion Starter · #2 ·
Murrays carbs then arrived.
Ordered some dials from a Custom CX500 - as I wasnt keen on the standard dials, but wanted to stay "kinda" standard.
Speedometer Gauge Measuring instrument Vehicle Tachometer
Have tested my rear light unit with a 9v battery.
Vehicle
Vehicle Motorcycle Automotive tire Tire Motor vehicle
Attempted to fit my Motad exhaust, failed when I realised it would clash with the under engine battery relocation box.
Land vehicle Motorcycle Vehicle Motor vehicle Fuel tank
Since have ordered new downpipes, CNC flanges, Murrays upswept midpipes and 2 slash-cut black mufflers.
In the mean time, while I wait for bits to arrive from the US. I have been rewiring with Mate-n-lok connectors, black sheathing and heat shrink.
Motor vehicle Vehicle Motorcycle Automotive tire Auto part
Auto part Engine Motor vehicle Vehicle Fuel line
So my build so far as involved:
So far:
Chassis
Gunmetal Grey powdercoated frame
(with rear loop welded in)
Satin black powdercoated Comstars
(with Continental Milestone CM1's)
Gloss black powdercoated swing arm.
Gloss black powdercoated centre stand.
Pillion footrests removed.
Norman Hyde 'M' bars.
Hagon black rear shocks.
All Balls Headrace bearings
All Balls Fork seals.
All Balls Swing arm bearings.
Replaced a lot of nuts/bolts with new Honda parts or polished if possible.
Black bar-end mirrors.
HEL - Steel front brake cables (Gunmetal)
CNC machined headlight mounts (Black)
Hagon rear shocks - Black
Custom made seat.
Electrics
Speedo / clocks from CX500C
Tri-LED Headlight with halo.
Ignitech DC-CDI-P2 (Replacement CDI)
Relocated Shindengen MOSFET FH020AA R/R
Relocated battery box.
(with Skyrich Lithium YT9B4 battery)
Rear LED brake/indicator unit.
CNC machined front indicators.
Rewired loom (and the wiring for the components) with new spashproof Mate-n-lok connectors, braided and heatshrink.
Engine
Polished engine block.
Head gaskets replaced.
Water pump gasket replaced.
Oil filter replaced.
Themostat + Housing O-ring replaced.
Idiruim Spark plugs - NGK 6681
Murrays tuned - 34mm Mikuni carbs
S/S Downpipes/headers
CNC Exhaust flanges
Brass Rod Mod
18mm Fuel petcock (from '79 Honda CB750 SuperSport)
My plan is to get the tank sealed and sprayed.
Get the brakes on it and get it MOTd.
Future plans... I want a CBR600rr front end with gold forks.
Looking good, mate! Look forward to seeing the finished product.
Thanks mate! So am I!
Just waiting on Murrays mids, then can get going on the exhaust.
My wiring harness is a complete state though - going to be time consuming :(
That's a great bit of work - mind if I ask where you got the headlight and tail/indicator lights from?
So tell me, what is it about the CX frame that makes me pop wood? There is just something sexy about that single backbone and the swooping lines at the rear. Kinda like a fine woman, I guess. The CX has and always will have a place in my heart.
Brooktini86, you're well on your way, I'm subscribed!
-tom
Reactions: brooktini86
Not the most exciting, but, more braiding while I wait for my murrays mids (Bet customs grab em)
Gun Trigger Firearm
Auto part Engine Fuel line Electrical wiring Wire
Motor vehicle Auto part Vehicle Engine Car
Auto part Electrical wiring Wire Engine Electrical supply
Cable Audio equipment Technology Electronic device Wire
Discussion Starter · #9 · (Edited)
All back on and left speedo can painted (poorly).
Motor vehicle Automotive tire Vehicle Auto part Motorcycle
Auto part Engine Vehicle Automotive engine part Metal
A very rough idea of muffler location
Auto part Motor vehicle Vehicle Automotive exhaust Motorcycle accessories
My seat wont completely go on, due to the mudguard bolts coming up through the same bar.
Auto part Fuel line Engine Exhaust manifold Vehicle
I could trim them down, but still wouldnt get it completely flush.
So thinking to make 2 holes in the metal seat pan.
Ceiling Metal
Then the back is looking nearly done...
Or you could put the bolts to hold the mud guard down from the top. Low head, button head or....c'sink the holes and use flat heads. And make a plate with two tapped holes to go under the mudguard so you don't have to mess around with nuts and washers.
Discussion Starter · #13 ·
The only thing I was worried about going this route was that people have already told me that I "will" have rubbing issues with the rear tyre, so with some bolts facing downwards, towards the tyres, seems a scary prospect.
I am using... Number 11 from here: Honda Cx500 1981 (b) England Rear Fender - schematic partsfiche
So I dont need any nuts and washers though.
Discussion Starter · #14 ·
So far:
Chassis
Custom made seat.
Electrics
Engine
CNC Exhaust flanges
Brass Rod Mod
Where did you get them lovely carbs from? And did a chap in Wigan hoop your frame by Any chance?
Discussion Starter · #16 ·
The carbs are directly from Murray on the forum! Message "murrayf" on here.
As for the hoop, I bought it on eBay and had it welded in by a local guy I know. Look similar then?
Discussion Starter · #18 ·
Ah right, i'm guessing you're the guy who sent him a photo then. I was talking to the guy on ebay who makes the hoops.
I'll message this guy on here now thanks :)
haha yeah thats right :)
Have drilled a hole in the seat tonight, so now it fits flush.
Hood Automotive exterior Vehicle Auto part Car
Bicycle saddle Vehicle Auto part Fender Metal
Motor vehicle Tire Automotive tire Vehicle Motorcycle
Discussion Starter · #20 ·
1 - 20 of 283 Posts
