1 - 2 of 2 Posts
Hey…I’m new…just bought a 1979 CX500 Deluxe and am cleaning it up a bit. It runs and starts right away but it is dirty and needs to be cleaned…I need to replace the rear brake shoes and change the oil and lube the points…
Question: is there an easy way to replace the throttle cables? They look pretty tight in there.
Thank you
B
I'm not clear on what you mean by "pretty tight in there". The throttle cables on these bikes aren't any harder to get at than the ones on any other bike. As with many other jobs the first steps will be removing the seat and the tank so that you can route the cables through the frame (there are diagrams for that in the FSM) and, of course, you will need to open up the right hand switch housing to get at where they attach to the throttle tube (twistgrip).
BTW: No bike of mine has had a return cable for over 30 years. The purpose of them is to allow you to close the throttle if the throttle return spring on the carbs fails but I've never heard of that happening and I've heard a number of examples of problems caused by gummed or rusted return cables.
1 - 2 of 2 Posts
