1 - 9 of 9 Posts
Hi Guys.
I bought a rusty CX 500 Custom because I like the look of the 16" rim. I had it powder coated and put it on my CX 500 B from 81.
I kept the shaft drive from my B model. I havent had the bike for a run yet- but it seems as the wheel goes around badly... The shaft drive had some thick greasy oil in it. See the picture.
I want to change the oil in the shaft drive- can it just remove all off the grease? Or do it need to be there? And what can it be- that makes the wheel go around bad?
Best regards from Casper, Denmark
If there is grease or oil inside the shaft housing then the final drive seal needs to be replaced.
Not sure why wheel is turning poorly without better description of symptoms. Make sure you have adequate grease and oil.
Final drive oil goes in #2 and drains #3, Self contained with breather #1. The grease you are showing is put in through the grease fitting #4
Auto part Automotive super charger part Automotive engine part Automotive starter motor Tool accessory
There's an axle spacer that fits inside the final drive from the wheel side. If that's missing, could it cause a problem in the hypoid gears?
R
Does the wheel have both wheel bearings? One of my bikes here has a floppy rear wheel because a bearing has been removed at some point, - presumably to pirate the bearing spacer tube.
1 - 9 of 9 Posts
